Which Software do I use?
2rlp
Sep 2006
Mumbai
136
I have been tasked with modifying a system that uses the following
  • BMXP342020 PLC and
  • HMIGXU3512 HMI.
I gather they are made by Schnieder Electric. But am not aware of the software that is used on this make.
Please someone point me to the right softwares
Software packages below :)
BMXP342020 PLC - Unity Pro
HMIGXU3512 HMI. - Vijeo designer
Can you really pay to reprogram the machine from scratch instead of getting the programming tools ?
Fine, whatever. I don't know the scope of the machine or how well his customer wants it to work, or whether he's got an infinite time budget.
I agree it seems ridiculous..plus the cost of the replacement PLC/HMI combo
If I was the customer I would reject the extra downtime & risk associated with this 'reprogramming', sounds like the OP doesnt even have a reliable code backup to work with right now
I'm not even sure why the OP asked the question in the first place if the decision to jump to another manufacturer is that easy....
As i said, the software works fine in trial mode for a good few weeks.
Unity Pro S. One of the better ones I used. But you will most likely need to get the .sta or .xef copy if it was developed in an earlier version.
I have already done 5 similar projects on Delta. So yes the software has already been tried & tested. The said project was left incomplete by a Schnieder system house about 9 years back. All I need to do is to install the sensors as per my requirement and change the PLC to Delta. This will be much cheaper than purchasing Unity Pro
Hi!! I'm looking for Temperature rise calculation software from Rockwell, I just download "Product selection toolbox 2022" but this software is...
107
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
97
I HAVE SMART TOUCH MS-60T-Pe MITSUBISHI HMI BUT I CANT FIND A SOFTWARE TO EDITE AND DOWNLOAD A PROGRAM IN IT.......CAN ANYONE HELP PLEASE!
45
Hi, Do you have any trick to make a software working when the 30 days demo version is expired? I've tried to uninstall/clean the registers etc...
243
My PLC (S7-1200 with CPU-1212C) has now been delivered to customer site. They've asked me to do some updates to the software. I can do that on my...
21
330
