FR S520S inverter reverse frequency problem
franz03
Mar 2016
Manila
Hi Guys,
I am using FR S520S 0 2k EC mitsubishi and when I run the motor forward, the frequency is the same with my analog output but when I run the motor in reverse, the motor is just constant to 25Hz. I tried just a simple forward and reverse motor program and I just set the analog output in "monitoring watch" and the problem still exists. Motor forward frequency follows the analog output of plc while in reverse the frequency is just constant to 25 Hz. How can I solve this?
It may be that a fixed speed (25hz) is programmed to the reverse control input. This can easily happen since many drives permit multiply terminal assignments.
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
79
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
16
499
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
89
Hello I am writing to request assistance with obtaining a specific GSD file for our Mitsubishi inverter type A800-E, which is connected to our...
421
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
199
