Accessing DINT to bit level: RS5000 to PV+
DairyBoy
Jun 2007
UK
393
Hi all. When allocating a bit from a DINT in a 5000 plc to say, the visibility attribute of an object in a pv+, the DINT as shown in the tag browser is not visible to bit level. Is it just a matter of inserting the bit number e.g. {[CIP_PLC]B0.17} ? The lack of verify facility (grrr) means that I'm using the help files a lot but couldn't find this one. Thanks.
You are correct that the FactoryTalk View Studio Tag Browser lacks a "bit picker" like the one in RSLogix 5000. You can only browse to the Tag datatype level, not to boolean sub-elements of the Tag.
You just add the ".xx" bit number to the end of the tag, as you've described.
Be sure to check the datatype that you're using Bits from; you'll get an error if you try to read Bit 16 from an INT or Bit 8 from a SINT.
Hi everyone, I am using step 7 Simatic manager V5.5 for S7-300 (cpu319-3PN/DP). I have created a udt in DB1 which contains DINT and I want to...
2,375
162
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
405
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
589
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,692
