HELP Converting .RSP to PC5
Cjohnson9127
Mar 2018
US
Is there anyone here who could possibly help me convert an RSP file to PC5. I have inherited an old system that I would like to get upgraded to ControlLogix. I am fairly new, and unfortunately my resources for these older files are pretty limited. Thank you for the help!
see if this helps ... I just used the default settings for the documentation ... let us know if you need anything "special" for your conversion ...
Thank you! I am attempting to run it through the translation tool, but it creates a file that 5000 tells me is not recognized as a valid project file. I am clearly missing something.
what version and platform are you trying to convert to? ...
the more details you give us - the more detailed we can make our answers ...
I am attempting to convert the program to run on a 1756-L61 version 18. I am just trying to get ahead of a project. I was under the impression that I could use the conversion tool to convert a PC5 file to a LK5 file that would run in Studio 5000, but when I do this my converted file will not open. It has a error that says the file I am trying to open is not recognized as a valid project file. Sorry this is my first go at this so I am not sure what information is relevant. Thank you for the help.
see if this comes closer to what you need ...
I got this to open on a V18 of RSLogix5000 for an L61 system ... the documentation is added too ...
NOTE: these translations are NEVER seamless ... you still need to go through this (pretty much piece-by-piece) to get things finalized ... there are a lot of opinions on how this should (or should NOT) be done ... but I think that this is what you've asked for ... good luck with it ...
here's a screen shot - just to show some of the translation "errors" you'll have to deal with manually ... (basically the "time base" settings for the timers, etc.) ... have fun ... and welcome to the forum ...
That is exactly where I was trying to get. Now that I can open on 5000 verifying the project and all should not be an issue. Thank you for the help!
Hello, I need some help with a rsp file. I cannot open it, because we have RSLogix 5000, but not RSLogix 5. I don't want to attach the file...
2,835
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
295
Hi! I am working on a project were we will be replacing an 300 CPU with a 1500 CPU and we are working on migrating / converting code. There is a...
1,061
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
464
Hope someone is really bored this late on Memorial day!!! I have spent the last 5 hours researching this and trying everything I could find on...
3,260
