Remotely accessing PVP
kcotton69
Jan 2018
Texas
I have a PVP 1000 connected to a compact logix via DF-1. I have remote access to the compactlogix via our ethernet machine LAN. How do I remotely access the PVP? I have tried drilling down in Linx but I cannot get to the panelview.
What are you trying to access remotely?? IF the PV has a VNC server, and its enabled, you could use the Google version of VNC viewer to see it. Going through linx with the ETH I/P driver or by manually adding the PV I.P. to the Ethernet Driver, you should be able to see the device online as a node in LINX but you can't actually see the application running.
Perhaps I misunderstand the question!
I was actually trying to upload the .mer from the pvp instead of having to walk my lazy rear end out there and get it via usb.
You can't upload through a bridge built between the Compactlogix serial port and ethernet ports...now if you connect the PV+ to the ethernet network, you should be able to upload and download to it through your network (assuming the settings and route are configured right).
Thats what i was beginning to think, but i wasnt sure
🤷 Hello everyone, This is a bit off topic, more about Raspberry Pi then PLC anyway... I was thinking if I could connect to my PLC (any...
4,927
Hello all, I know this topic has been discussed before, but technology changes every day and there are new tools we can use. This is my situation...
36
18,236
I am trying to connect to a remote Control Logix PLC. I have a gate way that I am told I can access. What I need know is how I can specify the...
4,253
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
281
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
174
