DB190 (Struct_DB190) RSlogix 5000 cant find Output????
AA_Ron
Feb 2016
Minnesota
43
Hey all,
So we have had this piece of equipment for a while but its a question that always blows my mind away when troubleshooting this piece of equipment. So its an XIO named DB190.DBX1_2 or DB190.DB1_3. I have tried to search my program for the OTE but cannot find anything. So my question is what turns this XIO on its almost like a panelview of sorts but this name on it and the nature of what it is doing tells me it cannot be a panelview input. Anyone have any ideas where I can find out?
Thanks guys
Good old Siemens memory emulation structures.
Try doing a cross reference on DB190 to see if the whole structure is not being written.
If not then it is probably being written by something outside the PLC like a screen or a write MSG.
Cool so i tryed to cross reference it but i still came up with no OTE so im going to assume they are I/O mapping or something. I need to take a look at the machine again it would be awsome to know.
From a FAT it appears that a struct containing bits/int/real can't be sent from a 1513 to a 1200. When using two 1513 there is no issue. Total...
698
Hi, I have this code: LAR1 P##structy L 0 T LW [AR1,P#0.0] which resets all the bits in this struct called structy...
641
Hi Crimson3.1 uses the GotoPage() to navigate to pages and the argument has to be a Display Page example: GotoPage(Page1); However since...
895
Hi everyone! I am working on a Siemens plc (1200/1500), and I have two instruction that i have to perform. A) data structure (40 bools, 40...
2,452
I declare a structure: TYPE sdoName: STRUCT i1: INT; i2: INT; END_STRUCT END_TYPE I declare a UNION: TYPE uName: UNION di : DINT...
3,052
