Help to start PLC programming first time
Tarar
Jan 2005
I am new to PLC programming. Can some one tell me which is the most used method to program PLC and from where I should start?. Should I start with Structure Programming (PASCAL) or FUP or AWL or something else?.
Thanks in advance
Tarar
Most PLC's are programmed using Relay Ladder Logic. However, many of the newer systems can be programmed in several ways, structured text, Function Blocks, and others.
You can start by clicking the LEARN PLC'S at the top of the page, and perhaps buying Phil's book.
You can also take at look at: http://www.thelearningpit.com/
Thank you very much
Mr. Moore and Herr Haase
It will help me much to start programming.For the time being I have decided to use FUP to start. Later may be some other option.
Tarar
To RMA,
I think that "Moin" is known to everybody in South too :) By the way I have been living one and half year in North too :)
I am in automation supplies industry and my company is planning to go through PLC / SCADA project. I have experience in PLC and SCADA programming...
1,963
Hi everybody. This is part number 3 of my new project with stuff we don't usually work with. Thanks to everyone who takes time to answer, it's...
1,581
Hello Everyone! It has been a while since I used the method of drawing a state diagram, converting that to Boolean algebra, and translating that...
2,967
I'm working on a Graphite that is continuously looping through the start up sequence then stops and shows a page that says "system could not...
4,908
Hello, I need some help from you guys to open an FIX32 Project that I got. What are the steps? 1. In the system configuration should the path...
1,492
