Data Access Error
akvotek
Oct 2010
Mexico
Good day all,
We are using a MicroLogix 1100 with a Panel View Component C600.
We are using a serial cable to communicate between the two and we get the following error:
"2: Data Access Error for Alias XXXX, Controller PLC-1, Address in XX:X, Communication Flag is 0"
Now, I've tried pretty much anything I can think of. Changing nodes, changing protocols, etc. And nothing gives.
I have a feeling I have the settings all wrong.
Did any of you have the same issue? I'm at a loss of how to fix this. This is a new installation, so it's not like the system worked before and now it doesn't.
Thanks in advance for any advice you can share.
Kindly,
Alan
Older thread I know (at least part of it) but I stumbled across it while trying fix the same error. In my case I was trying to display a timer value (directly) on my PanelView C400. The format of the timer register is such that it isn't capability with the Number display format of the PanelView. So in the ladder I used the Convert Any to Real function block, divided by 1000 to get it from msec to seconds, and that took care of the problem. Hope this helps someone else.
Data Acees Error for Alias A_THMC_REV_POL, controller PLC-1
136
Hi all. I am working on converting a PV300 to a PV C400. System is using a Micrologix 1500LRP with several expansion IO modules. Communication...
2,136
Hello, all, total noob here hoping for a little guidance. I bought a new piece of printing equipment that has a Mitsubishi PLC and this Data...
173
Hello all, PLC-programming noob here. I have multiple clients accessing some data on my Siemens S7 1211C PLC; some OPC clients and some direct...
30
8,303
Hi everyone, I'm working with a company that is developing software that will be used to access and process sensor data from different process...
1,893
