Omron Programmable Terminal
I have used the Keyspan HS19 with the cable.
I have not connected to a NTH25, but I have connected to other NT models.
Did you get the USB-CN220-EU from genius in training?
Usually his cables just work.
gtsuport
Yes Sir, that's where I buy almost all my cables.
Also in this system is an NT631C. I have tried to upload from that terminal as well and get the same alarm except that HMI displays this
On the NT631C, are you connected to port A?
Using Cable XW2Z-S002?
I am not sure what XW2Z-S002 is. I was finally able to upload from the NT631C after multiple times of shutting down software, disable then re-enable serial port on the craptop.....took almost 10 minutes for 700kB. Lol
I am still unable to establish connection with the NTH25 though.
I now have a new issue. The electrician powered the system down for 2 days and I can no longer connect to the PLC, like I did before. I fear the battery may have died and wiped the memory. I do have a back-up of the original however, it will not allow me to go online with it to even download it.
All the lights that were going blinky-blinky, no longer are. All I have is a power light on the power supply. Something tells me I am going to have to start from scratch, as if this is brand new.
Hey all, I have a question. I have a Omron CP1L PLC with a serial RS232 Comm port. I also have a Programmable Terminal, the NQ3-TQ00-B It no...
6,474
Hi everybody I have a new NT20M OMRON Programmable Terminal linked at a Mitsubshi PLC. When I'm turning on the power, the device (NT20M) boots and...
5,515
We got some equipment in from one of our plants that is closeing. There are 3 of the following PLC's in them: Omron Sysmac C200HS Programmable...
11,067
6,064
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
44
