Step7 upload hardware then download question
HJTRBO
Jul 2008
Melbourne
618
Hi all, just have a theory question here. Using step7 5.5.
I upload the hardware configuration from a dp or pn network that i do not have the original file for. (E.g a customers factory). Some of the slaves are third party (that i have no gsd file in my pg) so in the hardware configurator they are shown as dp norm.
If i was to preform a complete download (of the same system i uploaded in the above paragraph) at this point is it now a requirement that i obtain the gsd files for the "dp norm" slaves from the internet before download?
Hi
This happened to me last year and rather than take the chance I
Got the oem to do The change at big bucks but I felt t was safer as I did not know
The answer and still don't know but I would love to know the answer also
Donnchadh
HI
Thanks for that.
I did look at different manuals and even spoke to some other programmers but no one would say for sure. Thanks for your time and I do understand about manuals as I spend a lot of time reading them also but I just say the post and said well if anyone has the answer I would love to know.
Donnchadh
Hi everybody, Does anyone know how to upload hardware configuration from PLC to PC in SIMATIC STEP7. I'am using S7-400 does it make the plc stop...
8,331
I've tried few options to upload data from the cpu (WITHOUT having to stop/run the cpu again, but struggle a bit. Please help-out if you can! My...
3,958
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
130
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
141
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
127
