Gidding's & Lewis PLC
You Poor person
I have all the software for programming these horrible, horrible plcs you better bring plenty of panadol with you. Pm me.
You might want to call Sheffield Automation directly. Their phone # can be found at www.giddings.com. I have never worked with their older stuff, but the software for their newer systems (PicPro) is some of the best I have ever seen. Their tech support is also very good. Good luck. :)
Pic409 Questions
If I have some questions concerning the Pic409 programming software and its use would you mind helping me out? It looks like this piece of equipment was kind of difficult to work with compared to newer systems. I have several of these controls on machines. I would like to be able to download the ladder that is actually on these machines to see how it compares with some hard copies that may or may not be exactly the same. I have the 409 users manual that describes the Pic control panel that plugs into the front edge of the Pic Support Module and Programmers Consol Module. Am I correct in understanding that the software must run on the Support Module? Thank you for any help. Al ([email protected])
IIRC, the PLC ladder code is actually compiled into Motorola 6809(?) machine code so you cannot get the ladder from it. You must have the original source ladder file on your computer.
The people at Finger Lakes Control Integrators (http://www.flcontrol.com/) did lots of 409 stuff many years ago.
Haa, good old Motorola 6809e. Did a lot of assembler programming for that processor back in the good old days. First micro I worked with that supported indirect addressing.
First I'd like to say this was a working system before anything was done. The processor failed. I replaced it with an exact kind. I have a PIC...
1,581
I am trying to test a Giddings & Lewis analog (8) input card. I am using PicPro for Windows Professional Edition software with a PiC90 CSM/CPU...
1,266
Hi, I have an old Giddings & Lewis Pic900 Turbo PLC system with a serial card connected to a GE (cincinnati electronics) (Greyline) 3415 using...
1,846
Hello again guys Im just wondering if there is anyone here with any knowledge of G and L systems, we have a couple of machines that use this...
1,679
All, We are having troubles with a G&L PLC. The PRC40 is no illuminated. Does this store values? In the PicPro software it looks like we are...
1,476
