Telemec HMI (XBTGT2120) with micrologix 1000 plc. Anyone done it?
timbo_uk
Nov 2005
Bradford, UK
336
I got hold of the software for programming the HMI for free (legit promo from Telemecanique, I had bought their drive software last year.
I have a project up and running on one machine that was written for a micrologix 1000 plc (32 I/O).
I want to repeat this project onto another larger machine which if the operator control is done with switches and indicators would leave me with not enough I/O to use. I would then need to get out of the budget 1000 range plc.
I have been keen to learn to "do" HMI's for a while, but needed a non time-critical project to do it on.
According to spec sheets etc it should work, plus the software looks quite nice too, I have played around with it a little. I have managed to create a few screens that set and respond to integers within the simulated micrologix plc. So it does look promising.
Just wondering if anyone has actually used this mixed combination?
Any tips at all for am HMI newbie? I allready have one thing to think about, try to think what would happen if HMI failed!
Thanks in advance 🤞🏻
We use the XBTGT magelis touch screens with a micrologix 1200.
It works great. We have been doing this as our standard product for
a while without any issues.
Thanks, happier now (y)
Do the 1200 series use the same 1761-CBL-PM02 programming cable?
How did you interface the plc to the HMI? Do you just use one of the above cables on between, or do you need adaptors?
I did email rockwell support and got this back:
"The XBTGT Hardware / Vijeo Designer software is capable of being configured to communicate via DF1 protocol to various Rockwell PLC, including the Micro Logics 1000 (Channel 0).
You mention you have the software. I would recommend you create a project.
A wizard will guide you through the set-up.
Once you come to select the protocol select Rockwell Automation, then hit the help key you will then be presented with a table listing the possible communications hardware / protocol options.
You can then click on the hyper link for Allen-Bradley DF1 full duplex. You will be presented with a PDF detailing DF protocol and associated cabling.
According to the PDF for Rockwell DF1 we would recommend cable diagram is shown on page 12 of 32.
This cable connects to Com.1 of XBTGT2 series it is DF1 protocol over Rs232.
That means point to point connection, maximum cable length 50ft (15M).
Regards,
Jamie Coates
Product Application Support"
But I am confused here, I have uploaded a copy of the page mentioned.
Does this make sense to you?
Have you any simple projects for a QVGA HMI I could look at (not copy!) for ideas and best ways of laying out proffessionally?
I hope this is not a little cheeky!
I am trying to list all bits I need.
ÂŁ128 for the (XBTZG935) programming cable! OMG no wonder they gave the software to me for free!
Cannot decide if I need the Z9730 lead with or without the ZG COM1 adaptor. Why cant they make it clear for you!
Can anyone assist, as Telemec are not helping, all they will commit to is that it uses the DF1 protocol. Not very helpfull. I need to be sure of exactly what I need to sort out costings for a capital application.
Cheers (Hopefully!)
I would try speaking to your local Telemec automation distributor rather than Telemec. Mine down here in Surrey is fantastic and has even saved me some money by recommending the TeSys range instead of using a circuit breaker, contactor and overload. This saved me about ÂŁ50 on parts and then the labour to connect all the devices. Unusual to find a company wanting to make less money!
Jon.
Thanks for the advice, Ill try that. We also use the TeSys units on our own projects. Bonus is they are nice and quick to swap if there is a problem.
I have a telemecanique tsx 47 v:1.1-----2.4 ladder version v1.6 16k ram. I have to replace the ram battery, but iam unable to stop the...
2,093
Hi, I have a customer who has a Telemecanique TSX17, It is 13 years old. Working fine thismorning then all of a sudden a Line fault test string...
2,340
how can i identify the data ports(data + & data-) of tsx 3722 round 9 pin. b cos i have an rs 485 to rs 232 converter which needed 3722 Data ports...
1,639
Hello, I have a telemec tsx 217. I would like to know what software i need and what cable i need. I know it is very old. Telemec cannot provide me...
2,451
Hi, A couple of engineers at our place were trying to monitor a Telemecanique Nano on line the other night using PL7.07 I'm not quite sure of...
1,433
