autem plc analyzer - ethernet connection
logem2007
Jul 2008
istanbul
Dear All,
Related with the autem plc analyzer, I have one problem with the ethernet communication, i would appreciatedif you support to me.
Related with these problem, please find below the link of 6 pictures.
There are two plc and one CP343 module on the machine. These plcs are communicating to each other over profibus.
The names of the plcs are RE and UN.
The cp343-1 ethernet communication module is connected to the Plc which is named with RE.
After connecting this CP343 module with my computer over ethernet cable, i see all datas of Plc RE and Plc UN on simatic manager program without any problem, but when i try to connect with Autem Plc analyzer program, i can all datas of Plc RE but i can not see the datas of Plc UN on Autem Plc analyzer program.
i dont know, i make a mistake or somethink else. In my opinion i should also see these datas on autem program because simatic manager show all datas without any problem.
Hi I configured PLC Analyzer 5 to collect data from digital outputs but when i run program in CPU and start acquisition process, signal states...
4,687
Trying to learn PLCs going to start by buying an Arduino Opta Wifi to practice with but what's the PLC I should get next?
94
Hello, When I try to read from the PLC, the following error occurs: There is no project name. Failed to read the intelligent function module...
61
Hi, How to get data from multiple Mitsubishi Q03UDVCPU into master PLC Q03UDVCPU through QJ71E71-100 ?
44
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
136
