Factory Talk view License Ownership change
Usama_maqsod
May 2016
Lahore
29
what if i transfer the Factory Talk view License Ownership to my client's name whether i have to reinstall the factory talk view software??
Please someone can explain?
When you "transfer ownership" it just changes the records at RA.
Your client can then either....
1. Take ownership of the activation, by re-hosting to their PC, and setting it up as an "activation server". You will then be able to "borrow" the activation while you are on your client's site.
2. Take ownership of the activation, by re-hosting to an "activation dongle" (purchase necessary). The dongle can then be used to activate any single PC to legally run one instance of the software.
3. Let you keep the activation on your PC. Wise to get it in writing that they are letting you use the activation.
You won't need to re-install any software packages, everything is done through FactoryTalk Activation Manager.
Please note that 1 Activation will only allow 1 software package to be activated at any one time to abide by the rules.
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
316
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
279
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
566
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
354
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
663
