Can RSLINX Classic Lite communicate with a real PLC (SLC0)
IdealDan
May 2017
MA
480
Hi Guys,
Can RSLinx Classic LITE communicate with a real PLC (SLC5/04) on program Downloading event?
What about Transferring:
1. Transferring of .MER Factory talk file to a Panel View Plus, can RSLINX LITE do it?
2. Also During Simulation of Factory Talk Application .MED File with RSLOGIX AND EMULATE500, can RSLINX LITE do it?
Thanks in advance
Should be fine
I have never used Emulate but I would think it should be fine also if you are just using standard communication
No. Usually you transfer an application into a PanelView using the transfer utility (FTView Studio) and RSLinx Enterprise. Also it's possible to use a memory stick.
I suppose it's ok. The major limitation of Lite version is the lack of OPC/DDE capabilities. That's all:
RSLinx Comparison Chart
Do you mean I need RSLINX ENTERPRISE to be purchased or the one attached to Factory Talk View ME For the Transfer utility operation?
The included version should be all you need.
As for getting the RSLogix 500 Emulator to respond to a virtual HMI? I don't think that will work, but I could be mistaken. I do know that when (many many years ago) I needed to do this from other HMI software platforms, a licensed version (paid for) of RSLinx Classic was required along with OPC/DDE Topics.
I've created a test program in Micro Starter Lite and attempting to set up communications with the emulator and run the program. In the...
1,536
Trying to communicate to a network using the two mentioned in title. Can't really find a good video on how to do it. If I choose AB_ETH-1 I have...
3,171
I am trying to Install RSLinx Classic Lite on a remote machine so I can use the Clock Sync Tool, But I keep getting this error. Error 1320.The...
7,904
I downloaded rslinx classic lite v4.0 today only to find its not compatable with my version of windows 7 ultimate, anyone know what the mjst...
1,573
Under the "Ethernet devices" driver from RSLinx, I see all my remote devices when my laptop's wifi is enabled. Under the Ethernet/IP driver, I...
4,798
