Micrologix 1400 firmware email question
tacm
Jan 2008
usa
105
Hi folks,
A recent change has our email port 25 blocked. This has been no problem with email from PC's, as we can specify another port in Outlook, etc. MicroLogix 1400 firmware hardcodes email to go out using port 25, with no way to specify another port. So our alerts no longer work. Has anyone else experienced this dilemma? Any workarounds?
Steve
If you have a router between the PLC and the mail server, you could configure the router to forward port 25 to the new address when the PLC triesto send data on port 25.
i have one question related to micro logic 1400 is that i am using it as a on-off controller right now.if i want to use that controller as a analog input read then where should i connect my sensor wire and in program what should i select?
Hi, I've got a MicroLogix 1400 controller with a dead ethernet port. I'd like to update the firmware, but the download from Rockwell...
6,923
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
82
122
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
236
Hi everyone, I hope I don't butcher this up, please feel free to critique me wherever if I do, I have an issue I would equate to "chasing...
338
