Extruder screen goes blank by itself
shaneprasad
Feb 2017
lautoka
Hi guys ...we have a PVC Extrusion machine and there is some problem with the screen. The screen blacks out by itself although the power is on. We have to switch off the machine and on again and sometimes we have to do it plenty tmes to get it wrkng again. What could be the cause of this. Thnks
Could be a faulty backlight or loose power wiring. Suggest you contact the machine manufacturer and get a replacement screen if the wiring checks out ok. Once you have the spare in and working, you can pull the old one apart and check the backlight (look for manual for the make/ model of screen)
I have seen some Hmi screens have 2(two) screen saver's, ( 1 is backlight will turn off after pre-determined time and the other is a "Black or Blank" screen will display after a pre-determined time) both can be programmed to act differently.
You can sometimes verify it's the backlight by using a flashlight and shine on the screen. If you can faintly see the graphics then it's a good chance you have a bad backlight.
Thnks guys...the screen went blank while the machine was running ...all the motors were still running but there was no display of parameters so we had to switch it off again...but it wouldnt turn on..there is 24vDC power available to the screen but still it doesnt switch on...is there a possibilty that the screen board is faulty or has this got something to do with software issues...
I work on a plastic extruder that uses the following components: SLC 5/05 PLC Eurotherm T940 Process Supervisor -Eurotherm 2500 modules...
1,603
Hello. I am programming an extruder for the first time and I'm not sure how to control the heat and cooling for the barrel. I want to use a PID...
26
5,795
Has someone experience in communication of a Barmag extruder controller to an S7 or S5 plc? Especially if S7, is this possible with the buildin...
2,011
Hi I'm using RSView SE and i need an animation of an extruder leaning 45 degrees to the right (*.gfx file). can anyone give me such thing...
2,898
In one of the previous posts, someone talked about extruder control forced air versus water cooled. I have both types of extruders, I am using...
3,026
