SCRUFF
I have a PLC setup that is currently running two (A Redundant) Control logix Processors - a Primary and Seconday.
One important note to mention is that I am a newbie to Control Logix and this is my first Redundant Processors. I am trying to test the swapping of processors by disconnecting the fiber on the Primary Processor to see if the Secondary picks up. It does swap but the Secondary CPU does not swap to run mode. you have to physically select RUN for theSecondary and the same when swapping form the Secondary to the Primary.
Can any guru help me out on how to get the Processors (either one) to swap and come up running after the swap???
THANK YOU...
THANK YOU...
