gsv and ssv instruction
jcole1
Dec 2007
Kentucky
18
Hello guys and gals.
I have a processor instruction being used in one of my compactlogix called GET SYSTEM VALUE with the following info:
Class Name-ControllerDevice
Instance Name-
Attribute Name-Status
Dest-Processor_Status
I do not understand the field names (class, instance, attribute) or where controllerdevice and status come from. Its obvious something is being put in a tag called processor status which is an int data type but I can not figure out the purpose or where the data is coming from.
Could somebody enlighten me?
THanks for the replies.
regarding the following GSV terms:
Class
Instance
Attribute
turns out that they're basically just "blanks" that you may (or may not) have to fill in to get the GSV or SSV to work ...
secret handshake: don't worry about the differences between the three terms ... just click and select whatever you need from the "pull down" menus available for each ...
and here's a "general idea" post that might be helpful ...
http://www.plctalk.net/qanda/showthread.php?p=337631&postcount=4
Best way to look at the Class, Instance and Attribute fields...
Class - What am I interested in?
A Task? A Module? A routine? etc....
Instance - Which one?
Which task? Which module? Which Routine? etc....
Attribute - What do I want to change(SSV)/know(GSV) about it?
Last Scan Time? Fault Code? Inhibit Flag?
etc...
Destination holds the tag to store the data I/m asking for (GSV) or the datas I want to send to the controllers status (SSV).
Another analogy.
Class - What am I intrested in?
Answer: The houses on Maple Street.
Instance - Which house?
Answer: 3712 Maples Street.
Attribute - What do I want to know about it?
Answer: The color of the house.
Destination contents: Green
Some of the Class choices (CONTROLLER, WALLCLOCKTIME, SERIALPORT) will result in no choice for Instance because there can only be one CONTROLLER, WALLCLOCKTIME, etc.
All the info for GSV and SSV is built into the RSLogix5000 help system.
Simply click on the instruction name (GSV or SSV) and hit "F1".
The first page shows general info about GSV and SSV (usage, examples etc.). Scroll to the bottom of this first page and see the links for "GSV/SSV Objects". Follw these links to get detailed data on what the instructions are addressing in the System Value area.
HTH
All I am studying a PLC program from another facility. It uses an SSV instruction and a GSV. Data in SSV, GSV as follows...
7,387
Hello dear forum users, I have a system consisting of: RSLogix5000 v20.04 software Hardware Emulator v16-21 Executed on a VM Virtual Box virtual...
2,797
Hello Guys; I am new here. Also, New to the PLC so I took some college courses and also learning by myself. I came across GSV/SSV instructions...
1,610
In a ControlLogix/CompactLogix when using a GSV instruction, all of the objects are referenced by name as well as the attribute. When using a MSG...
6,870
My CompactLogix 1769-L32E has a minor fault: The GSV/SSV destination tag was too small to hold all of the data. How to fix the destination so it...
1,603
