PanelView Automatically Enable Barcode Reader
CobMoo
Nov 2014
California
Hey all,
I have a PanelView Plus 1000 and have a barcode reader hooked up to it. Currently, I can use the barcode reader by opening up a string input enable box and scanning the barcode. This inputs the barcode and closes the display. This all works fine.
What I would like now is to not have to press the input box each time I want to use the barcode. Is there a way to have the barcode reader automatically use that input box? Or if that is not possible, is there a way to open up the input keyboard display automatically when the screen opens. That way as soon as I open the screen, the user can scan a barcode.
Any help would be greatly appreciated.
Is that a manual barcode reader?? There are some manual barcode readers that has a read button, this button is recognized by the PLC. The you can use it to do whatever you want.
If you had a serial port barcode scanner, you could use Kepware and the UCON driver.
That solution would automatically scan the barcode directly into a string tag for you.
But it sounds like you have a USB barcode scanner, which is basically a USB keyboard. There is no built in support with PanelView to do what you are asking.
Hello,
I am working on a similar system with a USB Barcode Scanner that is hooked directly to a Panelview 7 Plus Standard. Was there any other configuration involved aside from using a string input enable box to populate the data in? I am trying to avoid using the Kepware and Ucon Driver. I just need to select the string input box and scan the barcode in it.
Thanks,
Hello all, I have a Panelview application (Panelview Plus 7 Standard, 2711P-T12W21D82) for which I am using FactoryTalk View Studio ME version...
3,582
76
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
52
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
166
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
77
