Access Processor error status in ControlLogix
siv
Aug 2005
dubai
30
Hi There,
Can some one tell me how to access the processor error status in controllogix controller.
I have used GSV instruction
as follows
class name: FaultLog
attribute name: majorFaultBits
Destination: mydestination [DINT]
class name: ControllerDevice
Attribute Name: Status
Destnation: Mystatusbits [INT]
Ihave placed both the instrucitons (GSV) under controller faultHandler.
When i created a major fault, none of the destination tags contained any value.
OR
Since the controller may not execute any ladder,Is it possible to access those data from other PLCs for example using "CIP Generic message?
Thanks in advance.
Siv
I have been through this same learning process and was surprised to learn that the FaultLog object gets written after the Fault Routine is executed, so that you cannot grab it as the processor goes through the Fault Routine.
The closest you can get, I recall, is to read the MajorFault Record and MinorFaultRecord using GSV from the Program Object, with "THIS" as the instance name (meaning the Fault Routine's Main Program).
I believe that the Controller state can be read by another controller. I know it's readable as an EntryStatus value when you have a Produced/Consumed tag.
What is most popular, though, is to let RSLinx do the work and use a Pre-Defined Item in your visualization software to show the state of the controller. Look in RSLinx (Enterprise or Classic) help for the Pre-Defined Items, including @Mode, @Status and @StatusNumber.
You have to be using RSView as an OPC server, not with Direct Drivers.
Just create a tag with the OPC Topic name and the pre-defined Item name in place of the Tag or Data Table address.
[ControllerTopic]@status
Hey, really simple one likely, but I am unable to gain access to our L85E processor web interfaces. We have flashed these into v.35 firmware which...
854
I was wondering if anyone had any feedback or reviews of any cellular remote access devices? I have a company who wants me to set up remote...
3,051
Hi, does anyone know how to unlock and OEM locked (MLX1500) processor? (Allow Future Access - OEM Lock Protection S:1/14 set on) We have a...
6,021
Hey Folks, I am trying to come up to speed with Ethernet comms for control of a servo drive using a CompactLogix L45 processor. I have RSLogix...
2,543
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
164
