RSLogix 5000 - Dialog Box Resize
pentiumvi
Jun 2015
Vancouver
Hello All,
I have a question regarding the pop-up dialog boxes in Logix5000, specifically for MSG instruction configuration.
My pop-up window seems to be cut off on one side, without an obvious way to resize my window.
Is there something I can do to remedy this issue?
Thanks!
Could the windows display options be affecting this? I had a different program with similar symptoms that were alleviated by setting the option in Control Panel > Display to "Smaller".
This is a known anomaly that is result of incorrect Windows font substitution
The technote 459871 has a full description and ways to correct it.
Workaround 2 in that TN is the best way to handle it
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts]
"MS Sans Serif 8,10,12,14,18,24"="SSERIFE.FON"
"MS Serif 8,10,12,14,18,24"="SERIFE.FON"
"Courier 10,12,15"="COURE.FON"
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
522
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
503
Hello all, I have a question in regards to RSlogix 5000. I am having issues with the program force closing when I try to make online edits. We...
116
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
127
