RS422 cable 25 pin to 9 pin
Steve_D
Jul 2002
Albury/Wodonga
92
I have a need to connect an RS232 cable to an RS422 port. I have a converter which is 25 pin in and out, I need to connect to 9pin plugs, I have the pin outs for the RS232 cable but don't have the pinouts for a 25 to 9 pin RS422 cable. Can anyone assist. I am assuming that all RS422 plugs are the same pin configuration.
Assuming you need the 25 to 9-pin adapter on the RS-232 side (to connect to your PC), you can use a standard 25 to 9-pin (male to female) adapter readily available at any computer store. Look in your "junk box", you probably already have one.
For reference, see THIS listing in The Hardware Book
beerchug
-Eric
Note to self... Always read posts thoroughly before replying...
Whoops! After re-reading your post, I realized that you need an adapter for the RS-422 side. I don't think these follow any "standard", though I've been wrong before (more than I'll admit!). If there IS a standard, THIS LINK might be helpful for the device side
You'll need to know the pinout of your converter (printed on side maybe?) as well as the pinout of the RS-422 device. What are you trying to connect to? You might find pinouts available from the manufacturer. Once you have that info it's easy.
RX+ to TX+
RX- to TX-
TX+ to RX+
TX- to RX-
Without that info, you're out of luck...
beerchug
-Eric
Thanks Eric
Thanks for the input Eric, I was hoping that wouldn't be the case as I don't have the pinouts for the Converter. I was hoping that all 25 pin RS422 pinouts would be the same otherwise, why sell a converter when the chances are the signals will not be on the pins you want??
OK. Let us in on it. What are you trying to connect RS422 to? What manufacturer? There's probably one of us that can help you out.
:nodi:
I didnt know that a RS422 device wouldn't follow the EIA standards that are set just like RS 232 is.
Two channel adapter port powered
25 Pin Female
1 GND
2 TD (A)
3 RD (A)
5 RD (A)
14 TD (B)
17 RD (B)
18 RD (B)
7 GND
25 +12volt
12 GND
NOTE that just like an RS 232 cable that 2 & 3 are being used to transmit and recieve. EIA RS 422 wasnt designed to change or be different than RS 232, it just allowed longer lengths. Follow the RS 232 pinouts and you should be fine
EIA does not define which RS232, RS422, or RS485 pin is which function. However there are normal conventions (especially in the computer market), but you always need to know what devices you are connecting to. For example a 25pin device is different than a 9pin, and some DTE connections are opposite from DCE ones.
Right now I have three different RS485 items on my desk and each one has a different pin out as well as different terminology (Tx(B) vs Tx(+)).
Convertors typically use PC conventions, but they are frequently used with custom built cables when connecting to non-computer ports.
I disagree but the EIA standards arent free, so I wont argue the point.
The difference is when connecting to DTE or DCE devices, nothing else
I have a Hitachi interface converter Rs232/Rs422 cable that I'm trying to connect a PC to a D100. When i try to connect, it tries for about 30...
1,737
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,042
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,906
This is a little OT but I'm looking for anyone with experience with the Yaskawa Sigma 5 servo drives. We've had some servo drive and motor...
3,527
Hi, Im a bit unsure about how to connect my SIEMENS encoder (5V TTL/RS422) To my baseunit (The light one).. I have attached a pic of how i have...
1,527
