Wonderware Intouch Assertion error
Apollas
Nov 2013
city
22
Hello,
I'm getting this error:
Assertion error - make note of error
File Y:\IntouchDev\src\sc-core-Irvine\database\rundblib\rdbgtset.c Line163
I tried to delete the following types: avl, wvw, ??k, but it didn't work out. Maybe anyone knows how to fix it or I'll have to recreate the whole project :(
Can it be because of the missing paackges?
Thanks in advance.
Regards,
Apollas
When are you getting the error? On start of Windowmaker? On opening a particular window?
You shouldn't have to recreate the application. Worst case, you can DBDump the tag database, import it into a new app, and import all your windows, scripts, etc.
Do you have access to WW developers support? You can follow this: https://wdnresource.wonderware.com/support/kbcd/html/1/recoveri.htm
and recover your app if your DB is corrupt.
You could also do a DBDump and open up the tag database in excel and look through to see if you see any duplicate tags or other oddities. If so, correct them, do a DBLoad into your existing application (change the first line of the CSV to UPDATE instead of ASK).
No, I don't have access to that site.
Thanks for a prompt reply. I think I will recreate it without huge problems with exporting/importing.
Thanks.
135
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
149
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
403
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
179
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
476
