High/Low selector
sayahan2003
Jun 2006
Calgary
181
My friends,
If in an application we have flow control with pressure override, or pressure control with level override or something like this, how do we know that the selector should be low select or high select? Is this related to the controller action (direct or reverse)? what if one of the controller is reverse and the other one is direct? or both direct?
Example from my world.
I want to get a certain temperature (by slowing down flow through a heat exchanger), but I want a minimum flow. Here the highest of the two determines the output.
I want a certain power use on a boiler, but I don't want to exceed my temperature. Here the lowest of the two determines output.
The question makes sense, it is just too generalized to get a good response. Maybe you are looking for general answers. Maybe you have some specific hardware that we can apply the question to...
Thanks boneless,
Your example are absolutely correct. My question is how you get to the result at the last sentence of each example(lowest or highest).
Thanks OkiePC,
This is a general question. I don't have a specific hardware.
please i want to know how to choose or select low or high selector for any applications.what is the reference for this choice...
1,364
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
166
If any of you wizards can help in this I would be ever more grateful. We have this device that generates 9 second pulses coming into a DI module...
31
3,402
I have 10 Hoppers each with 2 level sensors; one is at the 75% full level and the other is at the 25% full level. I need to fill hoppers that...
56
15,930
Hi All, I have been trying to adopt some of the HPHMI/Situational Awareness philosophies in my recent HMI designs and I've always been unsure...
3,496
