Trunk between 2 Stratix switch
yfcarer
Apr 2006
Tianjin
82
Hi guys:
I have two Stratix switch, one 8300 layer 3 switch and another 8000 switch downstream.
I created VLAN 60,61 at 8000 switch by below command.
- EN
- Conf t
- Vlan 60
- Exit
- Conf t
- Vlan 61
- Exit
At the 8300 switch, I created VLAN through IExplorer and defined IP address, and subnet mask. Note there is already some other VLANs defined at this switch.
Then I choose one port at each switch, use below command to set it to trunk.
-EN
-Conf t
-Int F2/2 (for example)
-switchport mode trunk
When I have all my cable in place, I cannot ping to each other, and the syslog on the 8000 switch says "Native VLAN mismatch".
What is Native VLAN? Do I need to set it?
In Cisco world, the native vlan on a trunk port is the untagged vlan; if you look at the traffic from a trunk port in a packet sniffer you would see that the traffic has a VLAN tag added to the header of the frame with the specific vlan that the frame belongs. This is how the next switch is informed as to what vlan this packet belongs.
So you will have this tag for all vlans except for one, and that is the native vlan. For Cisco, the default is vlan 1. So if you don't specify, packets belonging to vlan 1 will be untagged as they egress that port. All other packets from other vlans would be tagged appropriately with the VLAN header.
At the first switch where you created the two new vlans - are you sure you are using a trunk port?
You can verify the settings on each side with
show interfaces trunk
Example output:
Code:
2960G#show interfaces trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       1-4094
The native vlan will be called out. Check both sides of the link: what do they say?
Thank you Robertkjonesjr for your explaination.
I checked the setting on three different switches and get some screens in attached word document. SW01 is the layer 3 switch on top, SW06 is the new 8000 switch that doesn't work, SW04 is an existing 8000 switch which works with SW01.
The physical cable or fiber is connected as:
SW01 Gi1/2 – SW04 Gi1/1
SW01 Fa2/2 – SW06 Gi1/1
There is one difference on “Vlans in spanning tree forwarding state and not pruned”. The new switch shows none. Will this be the bad guy?
Example output:
Code:
Gi0/1       1-4094
It could be a spanning tree issue. I found this cisco bug from google:
CSCtf07138
Sounds somewhat similar. Next steps would be to debug spanning tree and figure out why those vlans are pruned.
Under SW01 / show interface trunk, there is only one port listed:
Fa1/2
Are there any others? This is not the port to either of your switches under review here.
Oh, For SW01, there are 5 ports in trunk mode. So attached screen.
I am thinking to run "show run all" to get all configuration to a file. Is this the right command?
I do "show run all" and get the configuration, do a compare as below.
Will the PVST vs. MST be the problem?
I thought MSTP was to be compatible with Cisco's per-vlan spanning tree but I never mix them so do not know what types of issues you might come across. Some googling shows issues such as yours - where some vlans are blocked. I guess I would make them all match and then go from there - if it starts working, then you know where you have to debug.
Thank you Robertkjonesjr. It works when I set the STP to PVST for SW06. Thank you for your help along the problem.
Hi guys: I am trying to setup the trunk for one stratix 8000 switch port. Below is the commands I entered through putty: - en - configure t - int...
2,359
Hello, Speaking of Device Net system, I wonder how to quickly identify whether the cable is a Trunk cable or a Drop cable? Thank you,
2,617
I am finding allen bradley doesn't have a pre-wired terminal block and cable for the analog 1756 and 1769 modules unless you also use the...
5,831
A question for those in the forum. Does anyone know if you are allowed to use Power Limited Tray Cable (PLTC) rated devicenet trunk in overhead...
1,798
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
