Siemens CP1613 with OPC Server on SR protocol
budtse
Dec 2004
Belgium
Hi, I'm trying to set up the OPC Server for Connection to an S5 PLC through a CP1613 Card. It's a re-install of the PC and the configuration worked before, so the configuration of the PLC should be fine.
One problem was that I don't have the original ScoreSR.txt configuration file for the OPC server, but I reconfigured the connection named S5FETCH.
When I try to read a variable (eg. [S5FETCH||CP_H1_1]DW160.1.1 or something like it (don't have the exact code with me)), the function always returns 0. OPC Scout doesn't seem to accept this syntax, so I can't test it there. It does show me the connection and 4 variables in the connection, but they all have bad quality.
Here is a piece of the trace log from the OPC Server :
18:54:47,963|0075 [ok] SRMD_open_req
18:54:47,963|0075 [ok] SRMD_notification rb=00CCB9B0 rb_user=13 rb_response=1
18:54:47,963|0075 get_open_cnf: cref=105
18:54:47,963|0075 [ok] SRMD_send_connect_req
18:54:47,973|0075 [error] SRMD_notification rb=00CC91B0 rb_user=14 rb_response=22 The connection establishment was rejected by the communication partner
18:54:47,973|0075 get_send_connect_cnf: fail cref=105 reason=02
18:54:49,465|0075 [ok] SRMD_open_req
18:54:49,465|0075 [ok] SRMD_notification rb=00CCB9B0 rb_user=15 rb_response=1
18:54:49,465|0075 get_open_cnf: cref=106
18:54:49,465|0075 [ok] SRMD_send_connect_req
18:54:49,475|0075 [error] SRMD_notification rb=00CC91B0 rb_user=16 rb_response=22 The connection establishment was rejected by the communication partner
I reïnstalled the whole software package two times, but it still doesn't work. I'm using Windows NT4 SP6a.
Any help would be very much appreciated.
I'm wondering if anyone has any insight into Siemens communications and may be able to help me with a communications problem I'm having? I have a...
4,189
Hi Guys, I encountered a broken PC on site. The PC was a Simatic Rack PC (industrial one with S/n :6ES7643-6DA31-0JX0).The connecttion to...
10,389
Hi, My PC fails to load the Device driver for a CP1613 card when the PC is rebooted. The PC is being rebooted whenever there is a loss of...
5,231
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
76
I have established an online connection to a machine using an S314 processor. I am using an mpi connector and simatic manager. The online...
77
