Rslinx Enterprise and Classic gateway
wilsonzhu
Jan 2008
vancouver
278
In my Computer, I already have Rslinx Classic gateway version to connect to PLC online by RSligix 5,500,5000. For another reason, I need RSlinx Enterprise version to Run FT View Studio software, Can I install both version into the same Computer(Windows XP professional)? Which's the procedure for that? Thanks,
While it is possible for RSLinx Enterprise and RSLinx Classic to compete for the same hardware resources (Serial port, ControlNet card, DH+ card) it is most common for them both to run on the same PC side-by-side using Ethernet with no conflicts or problems.
One thing you will wish to be aware of is that FactoryTalk View can use either an RSLinx Classic OPC Topic or an RSLinx Enterprise shortcut. Keep the names of the OPC Topics and the Shortcuts unique to avoid confusion.
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,409
Hey all, I have a FactoryTalk Gateway that I'm using for an OPC connection for a historian. This uses RSLinx Enterprise for finding...
4,409
Hi Guys, I'm trying to take backups of some of our equipment, PLC and HMI. In RSLinx classic I have all the ethernet drivers configured for the...
3,182
On rslinx classic I can change the subnet mask. At my plant I have 3 ip ranges (10.136.8.xxx through 10.136.10.xxx) with PLCS on them. In classic...
2,481
Hi, I have successfully interfaced a Micrologix 1400 and my panelview 1000. In the process I used the RS-232 DF1 driver/port to communicate with...
6,822
