search software OMRON NT2ST for NT2S-SF122B
terro53
May 2006
Mayenne
somebody can help me? I have a HMI OMRON NT2S-SF122B-EV2 and i can't use it with a PLC omron because i must programing it before use it?
Thank to help me ?
This is normal for most automation solutions, you have to tell it to do something, before it will actually do anything.
I have never seen the model you quoted, but by searching my omron manuals, I found that it is 'Omrons 2-Line Interface'.
Surprisingly tho, the software is not part of CX-One, or I did not install it when CX-one was installed.
Is this for a new project?
I suggest you start with obtaining the software for the NT2S, acquainte yourself with that, and come back with any more questions. There are a % of Omron people here, which brings me to ask, is this unit still in supply, or has the NS range replaced it? These types of displays are a good option for small installations, where data display required is minimal.
Hi, I need help on Siemens TIA version 12; Is it possible to search a tag and see where in the program is used at. I am looking at a code and...
2,391
He0llo to all, I recently acquired a customers site that has several(8 in total)AD EZ TOUCH panels and I was asked to make some programming...
1,686
Hi all, I need a piece of information:which softwares can be use with Siemens PLCs?There are VIPA and IBHsoftec;do you know others compatible with...
2,132
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
249
I have an InTouch HMI that has PID parameters. I need to find what the PID values were in the past. I have backups from the past, but none...
48
5,524
