.PVA file for PanelView 300
plcnovel
Feb 2006
LHR
215
Hi All
I have a .PVA file for panelview 300, but i can not be able to open this file in Panelbuilder32 software. I know i need to have .PBA file but i do not have that file available at the moment. Is there a way to open a .PVA file in PanelBuidler32 or to convert .PVA file into .PBA file? Thanks in advance
There is no reason that you should not be able to open a .PVA file.
You will have problems if it was created by a later version then you have. But post your .PVA file I will convert to a PBA if I can. ( I have ver. 3.82.00)
I've opened both type of files in myself in PanelBuilder32 (3.80.00).
Don't use the wizard to open the project, use File -> Open, by default it looks for .PBA files only, so you need to be sure to change the file type to PanelView Terminal (.PVA), you should be able to find your project :)
Hello! Can you convert?
Hello. At work we've acquired an old tubing end former machine we're trying to get running. The machine came with 2 floppy disks that have .RSS...
26
5,666
Hello everybody. I have a question and if somebody can help me I would be glad. I know that files transferred to a terminal are in a .PVA format...
29,464
I have a couple PVA files that I am unable to open. I have tried re-installing PB32. I have used versions 2.6 and 3.83. Want to see if anyone else...
1,154
I have a pva file (of old Rockwell panel) that I want to open. I do not have Panelbuilder 32. Can I open this in Factory Talk View, and if so...
10,148
can anybody help me to covert file PVA from a panelview to a PBA file my panelbuilder 3.80 wont open the file thanks in advance
2,323
