SENTRON PAC3200 and CompactLogix
Timer
Aug 2017
Germany
26
Hello, guys.
I have a SENTRON PAC3200 connected to CompactLogix L30ER. It has an IP address, it's set to Modbus TCP and now I need to read some values from it. Problem is - I have zero experience with SENTRON and the same amount with Modbus, so I need some pointers how to read for example voltage or current.
Any suggestion, like manual, or step-by-step instruction or program sample?
Thanks in advance.
http://stest1.etnetera.cz/ad/current/content/data_files/rozvod_energie/spinani_ochrana_a_mereni/sentron_pac3200/_manualy/manual_sentron-pac3200_02-2008_en.pdf
Here is the manual for the Sentron PAC3200. 3.9.2 Modbus TCP
This will list the addresses needed to read the information and the format that they are in.
http://www.plctalk.net/qanda/showthread.php?t=88357
https://rockwellautomation.custhelp.com/app/answers/details/a_id/470365/~/sample-code-for-modbus-tcp-master-and-slave
The above are links for L30ER Modbus TCP.
Here is a great introduction to Modbus TCP.
https://www.rtautomation.com/technologies/modbus-tcpip/
I hope this helps you out.
Regards,
Many thanks, got the sample code from RA site, imported it into the program and now I can read something. Not sure what exactly yet because of different data format, but that's already no big deal. :)
Hello everyone, I have a problem with communication between SENTRON PAC3200 (7KM2111-1BA00-3AA0) and MVI69E-MBTCP. I would like to retrieve data...
5,645
Hi everybody! I'm trying to communicate via modbus TCP an M340 and a Siemens Sentron PAC3200. I've tried with the I/O scanning and with the...
7,057
At my wits end.....I have a Siemens S7-1200 and a Sentron PAC3220 Power Monitor. Got the MB_Client command to connect and work in TIA 15.1 but I...
1,635
Hi guys Do you have some experiences with Power Analyzers such as Siemens SENTRON PAC4200?.. I have alternative analyzer installed on machine...
2,076
Hi to everyone, this is my first thread in this forum, I hope you can understand my english... I'm from Argentina I have a problem! I have a PLC...
3,284
