Baldor Drive Commissioning problem/error
RobbieNelson
Dec 2010
Logan, WV
Drive: Baldor MicroFlex FMH2A09TR-EN43
Motor: Baldor BSM80B375AF
Software: Baldor Mint
Error: Internal Drive Fault -> Internal Power Trip
Situation: Software seems to run fine. The Commissioning Wizard makes it all the way to the Tuning section. That's when the error shows up. Feedback from the encoder and hall effect sensors work fine. I can't find any info on the error. I'm using 120V single phase to power the drive. The internal bus voltage is steady at 170V. I've updated the firmware and reset the factory defaults. The error just won't go away. I have multiple drives and they all have the same error.
Any information would be appreciated. I'm stuck.
Disconnect the encoder and try to run the system open loop (V/Hz). If it runs ok that way, the problem is related to the encoder somehow.
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
48
We have an older Baldor drive connected to a motor that is a dyno. We currently have this connected to a test article that is just being driven...
18
3,771
Does this drive have a flying start parameter like the Allen Bradley drives have? I looked through all of them and can't seem to find one...
2,126
Hi Folks, This question is a little off topic. This is an integrated drive and motor which requires setup with a PC through a USB to SPI...
3,156
Folks, I have been saddled with programming a Baldor VS1SP VFD. The motor is driving a peristaltic pump and I want to be able to have the pump...
2,017
