Mitsubishi FX3U-16M GX Developer IEC
RheinhardtP
Oct 2004
Perth
562
Hi Gents,
I currently have the FX3U-16M and the Melsoft GX Developer software. I have a couple of questions?
1.Can one do function block and sub-routines in the PLC with this software?
2. Can GX Developer IEC be used?
3. Will the PLC be able to handle sub routines?
I intend also having a TCP/IP connection to a PC and two RS232 devices. There is alot of data handling and sub routines would be a requirement.
Any advice or inset will help!!
Rheinhardt
GX Developer
When you create a new program - the FB option is greyed out during CPU selection, so it doesn't look like its available.
Subroutines -You can break the ladder up using Program pointers P0 P1 etc but it will still be one long 'Main' ladder.
IEC Developer
Is more flexible and you can define POU's (program Organisation units)to structure your code properly, you also have FB's available to you.
Regards
Thank you
Thank you STL ,
I have looked at both versions and the IEC structured approach is definitely the one that i will take.
Thank you for the advice
Rheinhardt
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
160
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
359
hmi keeps saying "insufficient sensor failed" after the machine runs for 60 seconds. its a fx3u-48m PLC. The plc is not giving any errors or...
2,240
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,892
Hi All, I am looking to install a Red Lion CR3000 HMI and connect it to a Mitsubishi FX3u 64M PLC via Serial. I cannot find confirmation on...
2,824
