SLC 20A communication
gmultani52
Oct 2003
75
Hi
I want to conect slc 500, 20A to laptop. i have 1747-pic with 25 pin female socket, But my problem is that laptop having 9 pin serial port. how to connect my laptop. please advice.I also have cable C-10 which communicate to hht dirrecty. thanks
On the mechanical side, you most likely need to use a parallel-serial adapter(25pin-9pin). The adapter will plug into your computer, and the C-10 will plug into the slc 500. Do you already know how to set up the RSLinx?
Hi tom,
cable i will get from radio shack.
now how to communicate though rs linx. there maybe problem of password also becouse slc i purchaged from e-bay. so how to clear it. Thanks
As an additional note, a lot of people have problems getting the PIC drivers to work with Windows2000 or XP. I have been able to get 2000 to work, but have never tried XP. I've read that the older pic boxes are not supported.
In RSLinx, you will need to open the "configure drivers" box. In the list of running drivers, if you have anything running that uses the com port, you will have to stop (or sometimes delete) that driver.
In the drop down menu next to the add new slot, select the 1747-PIC/AIC+ driver, and add it. You will probably need to select the "reserve this com port for exclusive use" box. At this point, if using 2000, I've always had to shutdown and restart my computer. After that, you should be able to connect to the slc.
I wana communicate with AB PLC 1747 L20A, I want to now that how can it communicate with that processor I have RS 232 in my Laptop and also what...
1,611
I'm trying to read/write to an SLC5 with a ControlLogix L71 V35 plc that fails. The exact same code works on an L82S with V32. Is there a known...
70
I'm ashamed to admit this but I've never had to replace a battery in a SLC. Some how been able to skip that task in all my years. So yesterday...
209
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
792
Hello PLC friends. I've been going through a saga of diagnosing and fixing an old PLC setup that I inherited. I am learning as I go. Initial...
298
