Tropical installations
spaderkung
Aug 2007
South Sweden
389
Have anyone encountered liquid water inside junction and motor boxes as a result of condensation, not leakage? Solutions? An idea is 1 drilled hole in bottom that will allow gravity water out, but stop wind and dust blowing in..
I have seen that more than a few times. Condensation in a motor only happens when the motor sits idle doe a long time.
you can install external heaters to keep the motor temp up but here is a better solution
http://www.motortronics.com/pages/heatercontrols.html
it works without any additional wiring to the motor
as for the conduit the hole in the bottom of the box is a s good a solution as any as long as it not a hazardous environment.
Dielectric grease smeared everywhere? Same stuff is used on motorcycle spark plug boots. Stops moisture getting to where it does not belong.
Gel packs ( do no eat label ). Meat packing plants swear by these
I have seen so many 'weatherproof - waterproof enclosures filled with water that with due considerations to the conditions - I drill a hole where the water gathers.
Better than any watertight seal or gasket.
For enclosures I've also drilled my share of drain holes. I've even used a hammer and spike to create a hole when a drill wasn't handy - this actually works well because it creates a pitch to the hole.
For motors winding heaters are usually an available option. You just need a relay to put low voltage to the heater when motor power is cut.
For devices like electric motor operators on valves where a drain hole isn't feasible I usually specify a small cartridge heater and thermostat to eliminate condensation. This is also a commonly available option.
Like OkiePC, I see lots of those 4x boxes that will let water in but not let it out. A small drain hole helps if it's not in a "hostile" environment.
Put a T at the lowest point, then flex UP to the device/motor from the center of the T and put one of these in the bottom.
http://www.cooperindustries.com/con...d_drains/cd_series_ordinarylocationdrain.html
Yup. T to the lowest spot and install a drain helps.
Also, using duct-seal putty on the other end of the conduit (at the MCC) will help if the MCC is cooler than the plant floor where the motor is.
I'm working on a system that will be installed in an equatorial, tropical environment. I have been told that it will be under a roof but not in...
2,239
Hello PLCS.NET! I'm sure a lot of you have to do downloads/installations of Studio 5000 on your PCs. I thought I'll point out that even though...
41
35,114
And especially oil rig of different types? I´m thinking of trying some new branch out, someone here that have worked with design of systems to...
2,988
