Cimrex 20 HMI Program transfer
JuanPLC74
Feb 2017
Houston
23
Hello Everyone,
I'm working on a couple of systems that use Beijer HMIs.
One system uses a Exter K20m, I connect to it using RS232C serial and
I transfer and receive programs with no problem.
There is an older system with a Cimrex 20 HMI, I've never used those.
When trying to connect using the same method as the Exter K20m with a serial cable and quite the same comms settings (I've changed them in every possible way) I can't connect to it. I also don't find much information on how connecting to these two HMIs is different since the manual does not mention a difference in connecting with serial.
Is their pinout different or something? I have not find that information,
does anyone know a sure way to connect to it? (I'm overseas and I need to finish this HMI so I can get back home)
Thanks in advance
Regards
Pin 2 and 3 are altered when comparing Cimrex and Exter's RS232 ports (so the Exter cable will not work). The programming cable for Cimrex (RS232) is called CAB5.
Hi. I need to get an upload from a Cimrex 30 HMI. According to a label on the back, it's made by Beijer. See attached photos. It's successfully...
2,594
in our old machine we used beijer cimrex 41 need to take program backup. i tried it with information designer software through ethernet. ip...
84
Hi all, We need to change the IP address on an old Beijer Cimrex 91 we have in the field. I know there's a switch that you can change the position...
1,756
i m facing problem in establishing communication b/w Cimrex 20 and **** **** is modbus master on RS 485 as per **** it will take updates from...
12,273
26
