Someone help please
IdealDan
May 2017
MA
480
Rockwell Migration guide did not state any action for the correction of below error:
Screen 4 - 82PK961C_D: Message display object will be converted to Multistate Indicator object at (214, 70).
What could be a possible solution to this please?
Please explain what hmi terminals you are working with and what you are trying to do.
model numbers and software also.
james
Thanks for responding!
Panel view 900 to Panel View Plus 6 1000
Software is Factory Talk ME v9.0
I want to know the exact thing to do on objects with this type of error message after converting from panelbuilder32 .pva file to FT
Your input will be appreciated alot.
It could be that you don't have to do anything; other than verify it works correctly.
That object usually converts very well.
In PanelBuilder look at the object, the tag connection, and the state changes that the object makes.
Look for state values, text, colours, images, etc.
Compare that to what the FactoryTalk View ME object has setup for its states.
You've really been helpful, thanks alot
I'll immensely appreciate your help on this error below:
''Bit and LSBit triggered alarms that used a Trigger Tag with a Bit data type will only be able to trigger a single alarm after import.''
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
6,955
Can someone please convert this file to PDF from RSS thanks,
2,130
im trying to do this secuence but it dont work :(
2,530
Im trying to create a save button that will allow the data once inserted in the form, save to a notepad file. The file can be accessed later for...
1,546
Our instructor never taught us how to use the internal address or how to interlock. Any help would be appreciated! Thanks in advance...
29
7,175
