Panel builder help needed
stu
Aug 2005
England
783
Hi guys
I have a question to see if it is possible to display a cycle timer slide display on a panel view screen ?
I have a machine that we would like to capture the time it takes for a Press to pre press a product then press the product to a set time (which is the cycle time)
And display this on a panel view screen ?
Our thoughts is to have a slide gauge displaying seconds of a cycle
Do you think this can be done thanks Stu
Does your machine already have a HMI installed on a control panel.
The short answer is yes, you can. An quite easily.
Hi rob yeah it’s an exciting machine
I have captured a cycle using a timer in rslogix 500, but thinking a slide display work ??
Here is the ladder that I am trying to get to work and then display the time ? What’s your thoughts any ideas , I appreciate your help thanks
I notice you reset the RTO when the cycle has completed.
Personally I would use 2 RTO's.
On the first cycle move the .acc into a store area. Use this to be viewed on screen. Then you can reset that RTO.
Use the second RTO to start timing as soon as the first stops so you have no latency in timing. Move that into a storage area once complete.
Rinse and repeat.
Hi can you show me so I can visualise it , I think I see what you mean, I will have a look at this at work tomorrow. Thanks for your help stu
Hi Rob
What was your idea in moving to a storage area ? I’m new to this sort of thing?
Thanks stu
Have a great xmas guys all the best
I am not well versed in PB32, so i am needing some direction I will be short and direct. I have a panelview 600, communicating to a slc 5/04...
2,190
Ok I am using panel builder 32 and a allen bradley panel view 550. So I put a got to screen slector and I can go to objective properties and set...
3,149
Does anyone know where I could download panel builder 32 for old rockwell HMI's? Our supplier is no help and we are struggling to find the...
899
When using Panel Builder 32 I am adding a tag and the array size seems to default to 0 on floats and integers. I am wondering if this will...
1,129
I just finished making my 3rd service call to a large machine shop, troubleshooting PLC issues. I can see that none of the PLC or HMI programs are...
3,051
