Proficy Machine Edition not recognizing my USB license
defcon.klaxon
Feb 2015
Far NorCal
616
Hey guys,
Seemingly out of nowhere, when I open a project in Proficy (8.6) I get a pop up saying that my trial period is ended and I need to authorize, otherwise I can't verify/save/etc. I've put a call in to my rep but haven't heard back so I'm pretty much dead in the water right now. Not sure why this would occur, I've been using the same hardware key (USB) for months now. Any idea on what I can check/look for/do to get this taken care of?
Of course I start having this issue literally a day before I'm scheduled to start integration!
Start by running Proficy License Viewer to see if it still recognizes your key. Does the key appear in Windows Explorer?
All Programs/Proficy Common/License Viewer. Be aware that it will look like nothing is happening for a long time after you launch License Viewer, maybe as much as a few minutes, so give it plenty of time.
Windows 7 or 10? The first version of PME to be officially certified to run under Windows 10 was 9.5 (I believe).
Hi Steve,
Thanks for the reply. I did some additional messing around and it seems like if I move the USB key to a different port, that helps alleviate things. Not sure why that would matter but what I did notice was when I moved it around, Windows wanted to update the drivers for the hardware key software, and then after letting it sit for several minutes it's working as intended. Weird, but glad it's back to working. Oh to answer your question, I'm running 8.6 on Win 7.
I have also seen Windows have to update the driver for the license dongle. I don't know exactly when or why it happens. It may have something to do with Windows updates although I've never paid enough attention to notice if it happens after each Windows update.
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,372
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,115
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,012
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,019
