NovaTech D/3 Process Automation System ?
cntrlfrk
Feb 2006
Nebraska
244
I was curious if anyone out there has any experience with the D/3 system? I really know very little about it. What type of programming language does it use? Is it considered a PLC type system or a DCS? Does anyone have any sample code I can take a look at?
One of my coworkers is a former Novatech programmer. He loved it. I will talk to him about where to find the best resources and post it here next week.
David
D/3 was started many years ago by Texas Instruments (TI)Process Systems Division and sold in 1994 to GSE. There are still some systems out there. Programming from what a person showed me was similar to Pascal.
Can someone explain to me what a FGB is and what it is doing in this pic? Thanks
1,348
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
72
Hi All, Im using Cimplicity 8.2. after the last restart Server Scada, the PTDL_RP process can not running. so Process can not be login to database...
156
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
854
Hi, When I use an interrupt OB (let's say OB38 which is processed every 10ms), does it read the state of the inputs at the time it is called, or...
18
2,380
