S5 CP143 SINEC software ?
antoine
Sep 2002
62
Hello,
We have an S5 PLC with SINEC ISO/OSI communication boards 6GK1143-OAOB1 (CP143)
I need to go online but my brand new console has only the NCM software V2.07 which I use with the "new" generation of CP1430 TCP/IP
As soon as my old PG710 passed out last year, I am kind of stuck !
Does someone have the old NCM software or any useful link ?
Any other way to go online ?
Thx
Antoine
Found this archived away, it contains some old COM packages from around 1991:
COM143 V1.1
Also:
STF-DB Editor V1.1
PG-LOAD V1.2
COM-EPROM V1.81
I also found this:
SINEC NCM V1.01
but this was for the CP5430
It's too big to upload here but if you want to give it a go drop me a PM and I'll get it to you somehow.
**edit**
Ooops - that's a L2 module
The only other SINEC NCM for a H1 module I have is:
SINEC NCM V5.01
from around 1995 which is for the CP1430
Hi guys,
Bit of a grave dig, but just wondering if anyone has a copy of SINEC NCM V1.01/COM5430TF?
Need to change some parameters in an old CP5430 card in a S5-115U rack.
Hello there,
I'm looking for the 1.04 version of NCM in order to configure a CP1430TF.
A huge thanks for your help !
Regards,
Jean
Greetings, guys.
I'm looking for Sinec NCM for CP5431.
Can you help me out?
I don't even know where to look.
Google led me here. I've downloaded V1.1 krk uploaded, but it supports only CP5430.
I'd appreciate any help.
Thanks in advance.
~Chuck
Try this.
(Not sure what's in here as I haven't used it for many years)
SINEC NCM V5.01
CAN YOU PROVIDE IT?
Thank you for the software,
i have already installed and it looks ok.
I have no idea about simatic s5, i know about s7.
Imaging, it is s7, how to define this new card cp1430 in the hardware configuration??
How to do it in s5?
Can you advice?
Thank you
Hi, I'm ordering one of these this week, but wondering what lead I will need to connect them up? Is it just a AUI 15 pin lead? Or will I need...
1,894
Hello! Does this module need any supply card for the 15V? 15v fault lit and there is no voltage in the AUI port. I don't find any manual on this...
2,262
I have a WinCC V4.0 with a CP1413 card who is communicating with a CP143 (S5) over Sinec-H1. This PC will be replaced. The new PC will be equipped...
2,760
I'm getting this message when I try to view the CP Status while online with it in the NCM software. I've tried deleting the DB in the CP and then...
1,972
Hi, I would like to find the procedure to setup PCLink2 (ISA card in PC) to communicate with Siemens CP143. I know that this card is very old...
3,642
