Omron High Speed Counter
SeanLee
Mar 2004
Minot, ND
122
I have a Omron C200 Series Controller using CX-Programmer with a high Speed Counter monitoring an encoder.
I think i have the programming figured out for the Counter except one.
There are three different Speed settings for this machine so in the DM i have what i believe is the Original Memory location for the IR to reference the Parameters. Then there are 3 other memory loacations that contain parameters for the 3 speeds.
We are only using the first 11 ranges so that leaves me with 4 left and i want to use 2 of them. I figured that sence the DATA Transfer is only transfering to the first 11 i could enter my Parameters into the original Destination. NO DONT WORK
There is always a Data transfer the memory is never just off the original loaction. (Dont ask me why i think the guy that did the program was on crack and my supervisor wont let me Start from scratch)
Well the questions is what exactally is going on when this transfer is made, It does not change the parameters in my Original Memory. When i do enter in parameters for Range #12 the Range #12 Flag bit comes on but the Output #12 Flag bit does not.
WHAT IS GOING ON?
So wh
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
874
Hi Folks. I have a problem with an Omron CPM2A-60CDT1-D High Speed Counter. It had been working well, the problem arose when a very minor program...
1,464
Hi Folks. I have a problem with an Omron CPM2A High Speed Counter. It had been working well, but the problem is that a program change was...
1,366
Hi, I am growing in my Omron knowledge, but this one has me scratching my head. We have a customer with an Omron spec project that wants to...
2,963
can help me? how to setting PLC and write program(cx programer v9) for recieve data from increment encoder? Please give examples. thank
10,847
