Omron CS1H CPU Cycle Time Error
minaykha
Apr 2009
singapore
96
Hi Everybody,
I am using Omron CS1H CPU in one of my project.
There are five machines using same CPU, same program and same design ( meaning 5 duplicated machines )
But, one out of fives machines frequently trigger the
cycle time error alarm and machine stopped when this alarm trigger.
As CPU series is same and program also same, i cant find out
why this cycle time error happen and where the problem come from.
Dose anyone has any suggestion or similar experience ?
How can i fix the cycle time error alarm ? Thank you.
I just want to share the info.
Problem was HCA tool switch.
I put the HCA tool switch to OFF position, after that, no more cycle time error.
We have 2 same machines ,The PLC is omron CS1H-H ,CS1W-MC421,One machine the cpu broken ,Then I replace a new cpu module,use the CX-programer and...
2,005
Does anyone know what the maximum limit of I/O is for the Omron CS1H-CPU67? I think it is 10,240 (5120 local and 5120 remote) but having a hard...
2,244
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
209
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
129
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
223
