1394C-AM07 dc bus fuse
technolog
May 2015
Ohio
320
I have an axis module with its Axis Enabled LED flashing red & green and a fault displayed on the system module of Ax0:Bus Loss.
I found that the fuse in the axis module was blown. The blown fuse is a Bussmann FWP32A14Fa. I suspect it's the correct one but I'd like to check what the recommended fuse is. I've scoured various manuals and Rockwell's literature library but can't find the answer. Does anyone know what it should be or have a suggestion of how to find it?
Hello all, Before to action i have a question because i'm not sure about a thing. I have a damage Kinetix 1394C-STJ22-D series D, firmware ver...
1,779
How do you remove the program from a 1394C-SJT10-C-RL?
2,266
I have a 1394c-SJT05-C-RL Servo controller. The unit powers up. I cannot communicate using GML Commander. The light is blinking red on/off. Any...
1,915
Can I use a 1394C-SJT10-T-RL controller in place of a 1394C-SJT05-T-RL, if everything else remains the same? Where can I purchase a...
1,341
I am trying to connect a GML Commander to a 1394C Servo using USB to RS232 connector in WIN 7 / WIN XP. GML Commander allows ports 1 to 4 only...
3,057
