Connecting HMI to plc in another TIA project
aand74
Dec 2005
Deinze
131
We have a project with S7 1500 and WinCC professional (TIA).
The WinCC professional should also display some screen of another S7 1500 plc.
That PLC is from another machine builder.
The machine builder has his own TIA portal project, and will continue to use that one, and will not use a project that contains all hardware (our plc and their plc).
I now should copy the HMI srceens he has prepared in his project to my project.
What is the best way to connect to the tags of his plc?
Do I put in his plc in my project (with at least the datablok containing the variables referenced by the tags)?
What if his databloks have optimized access?
If he adds one variabele at the end of a datablok, will the old variables above still be acceseble by my HMI?
Or how should I do it : the machine builder still using his own project for the plc, and I accessing tags in his plc from my own project?
I question the logic of importing the HMI from another project, in order to assemble all in one common HMI.
It is certainly doable, and there are several strategies to chose from.
But as you are already seem to worry about, the problem is that every change in the machine HMI has to be recreated in the "common" HMI. This may be a small nuissance or it may be a big problem.
And there may be an issue with who will be in control when there are 2 HMIs for the same machine.
Is it an acceptable compromise to use remote control of the local HMI via smartservice ?
When using smartservice, the user on the remotely controlled HMI will be locked out. This may seem as a nuissance, but it is actually a proper way to do it. In this way two operators will not "fight" each other.
The machine builder will not deliver an HMI.
Normally he does in his standard machine, but here the customer wants it to integrate it in het main HMI. We can consider that after startup, the machinebuilder will not, or not often make changes to the program.
I just want to know if copying his plc in my project would be a good option, or if I realy need to use the proxy function.
The machine builder will work in his separate Tia project.
Hello, I'm currently working on a project with RSLogix500 and Vijeo Designer for my HMI. I use RSLogix Emulate 500 to host my PLC program while...
2,008
Hello to every one I have a delta plc with model dvp12sa2 As you know this type of plc has 3 coms , com2 and com3 are rs485 I want to connect...
3,979
I am using Weintek MT8100i HMI and Schneider Modicon M340 PLC. In easybuilder file, I have Defined the PLC as Schneider Modbus TCP/IP type. Now...
16,551
Hallo, I'm supposed to write monitoring application of PLC. I've got following idea. I'd like to disconnect HMI (Mac40+) from PLC CPU (A2AS1) and...
7,688
I am trying to backup a program on a Windows 10 IPC running an application written in TIA v16 and download an update. The system has a Siemens...
2,168
