How to read/write between SLC500 and Controllogix via ethernet?
wilsonzhu
Jan 2008
vancouver
278
Hi all, I need to write program to read/write data between SLC500 and Controllogix via enthernet, For my knoledge, it can use MSG instruction, but I never use it before. Does anyone have any information or experience about that? Thanks a lot!
There are two things to remember when doing this.
In the control logix you need to create the path directly into the MSG instruction.
ie "LocalENB,2,192.168.0.1" will get you straight to 192.168.0.1 through your 1756-ENBT module.
secondly, you need to use Logic->Map PLC/SLC Messages to map a file number to a tag name for the SLC to Control Logix comms.
Everything else is pretty easy to figure out.
Greetings. I have a 1769-L30ER that runs a new piece of equipment my company bought. I would like to read from and write to some tags on this PLC...
1,423
Dear all, glad to be here and I hope that we all can benefit from this great community. I am trying to send and receive data between two Mico850...
2,726
Is it possible to use a MSG Block in a Compact Logix processor to pull data from a Mitsubishi Q series ? Or do i need to employ some kind of...
2,903
Hi. How to read/write complex datastructures between two runtime in TwinCAt 2. Do I have to define anything within system manager? E.g. How to...
2,111
