rslinx and Excel with AI Icom software
mulderm
Jun 2003
Netherlands
298
Hello,
I have 5 PLC5/25 plc´s working on a DataHighway+ network.
There is a laptop with Windows 95 and Icom AI series software
for plc5 installed using for programming.
I know that RSLogix5 is the best option but many people can´t
working with these because they have experience with AI series.
Now I want getting data from a PLC5/25 processor to an Excel-file
using a desktop with Windows XP, RsLinx professional and Office 2002
installed and using a KT communication card.
I will use DDE to get the data from a plc5/25.
Is this possible?
Because there is a laptop with the old AI series software, give
this a conflict with RSLinx?
Who can help me?
Greetings,
mulderm
If you can see the topic in linx there should be no problem pointing to it from excel. I have only done this excel - rslinx - control logix - over ethernet but if you see it in linx you can grab it from excel.
Very easy
There is no conflict between using RSLinx and using an AI-5 station on the same DH+ network as long as they have different Node numbers.
In RSLinx Professional, you will create a "DDE Topic" that references a specific PLC-5/25 controller. You may then make DDE references in Excel that use that Topic. The easy way to do that is to use the "Copy DDE/OPC Link" feature in RSLinx.
There is extensive documentation on using DDE and Excel in the RSLinx Online Help and in the RA Knowledgebase.
Hi, I'm brand new to the forum and spent some time looking around but could not find an answer to my question. I'm using an excel spreadsheet to...
1,332
Hello! I am trying to help a coworker get access to a company dashboard. It runs on my computer and I have set up similar dashboards myself, so...
2,506
Hello All, I know it is possibile to access data from a PLC directly to excel using a OPC link through RSLinx...
1,734
I use dde/OPC to read tag vaule in excel file its working ok when rslinx running NOT as service but when I run rslinx as service I got an error at...
1,923
Sorry if this is off topic, but this is more of a VBA question. I have some data that needs to be collected weekly. I have an excel sheet so that...
2,097
