Simalating a touvh panel with Step7 basic runtime without having a touch panel.
Dreeten
Dec 2010
belgium
Hello,
I teach some plc programming in school.
I have a project that i would like to expand with a touch panel.
But, i dont have one...
In an workshop from siemens i did an exercise with a s7-1214c and a touch panel. There i had the panel and could test everything on the panel, no problem. After testing the panel i removed the ethernet cable connected to the panel and i was still able to run/control the plc with the runtime simulator. So i clicked on the simulated touch panel on my pc and saw the output of the plc reacting.
So i am thinking it should be possible to use a pc acting as the touch panel at school. Could this be true? Or do i need a touch panel connected at least once before i can do that?
If it is possible could someone give me a link or document i can see to explain how to set it up?
Thx
you can use Wincc Flexible runtime software but would need to have each cpu licensed i bet
I do it to remotely connect on a project or if you have an HMI with embeded webserver, you can acess the hmi files pages remotely via web explorer...
@KalleOlsen: I tried that, but then i need to fill in the data in an "excel-cell". And i want it set up just like a real hmi screen.
So if i click on a run button on the hmi screen i see the motor connected to the plc starting. And vice versa , if the motor is running i want to see a indicator light on the screen lighting up.
I get in trouble when compiling the project. Ill take a pic of it when i get back to work (after weekend)
@Jeff23spl: im note quite sure what u mean with remotly connect on a project.
thx for the replies !
On the screen capture you posted, select the Runtime option. If your PG communications are setup correctly it should work. There is a FAQ on the Siemens support site outlining how to do it.
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
195
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
381
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
80
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
277
I copied a panel in factory talk HMI for an identical system. The label names are still the same as the original panel but I am trying to change...
126
