DC Power Supplies
Rookie_Engineer
Guest
R
Hello,
I consider myself a rookie in the Controls industry but I am learning fast with the great wealth of information on this web site and others. My questions is about DC power supplies. I am curious what your opinion is on switching and linear power supplies. Do you consider switching technology sufficient for all applications for your projects? Or is your choice based on applications besides load requirements for example powering sensors, Digital IO.
Thanks for the feedback and continued posts on this website!
I've been using switching power supplies for about two years now in all my controls project.
I used SOLA ones for awhile then we found out about Murr power supplies being cheaper...we used those for awhile about a year, then this past week I had a problem with a Keyence CV-751 color vision system which runs on 24VDC. I had a Murr power supply installed in the panel...
It turns out the Murr power supply was causing all the power problems to the Keyence Unit. So I bought a Sola SDN-5-100 power supply and all my problems went away on the Keyence unit.
Lesson learned? You get what you pay for sometimes.
I've used the following switchers:
Sola - I recommend, sola has been in the power supply business a long time, even back when all that was left was linear type SOLA was the way to go.
Murr - cheap but not stable in rush power up problems
Pheonix - expensive just don't like the terminals either
Omron - ok too big of a foot print in most of my cases. They seem really nice, I just wish they would get as small as the Sola to save more space.
Good Luck
ab
look for new allaen bradley power supply
very small with high output powering. But expensive
Can installed on din rail
Joe Joe,
The new AB power supply is made by the same company which makes the Sola, so why pay for the name when you can by the Sola and get the same thing?
Mike
rogerhollingsworth,
I did a little research on the Sola/AB thing and what I have found out is that Sola did not make their own power supplies. A company in Germany named Pulse was making the Sola units, apparently Pulse and Sola did not see eye to eye as of late, so Sola and Pulse split company. Now Sola's power supplies are manufactured in China and will have a different part number from the old ones. Pulse on the other hand went to AB and is now selling AB all of the old Sola power supplies.
I am sure that the AB units will be priced higher than they were as Sola, but you know you have to pay for the monogram.
Mike
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
107
is this possible? i have a customer has has a large factory, he has 2 x 800amp supplies coming into the site and would like to switch between...
919
Hey Guys, Can anyone recommend a P/N for 48VDC input, 12VDC output power supply. I tried looking up Phoenix Contact/ RHINO, and wasn't able to...
1,482
Is there any problem with connecting two or more 24V DC power supplies in parallel to get more Amps? I have one 40A supply on a large machine...
21
7,388
Hi all, I was hoping someone could tell me if there's an advantage between using PULS or AB power supplies that are rated for SELV and PELV? I...
1,980
