allen bradley rs5000 sequencer instruction help
melbert
Nov 2002
northen minnesota
:( I am a student working with rslogix5000, and allen bradley 5550 plc. I am trying to use a sequencer instuction to sequence some robot arms. I don't know how to set up the array. I keep getting errors like: invalid array subscript specifier, invalid array destination. What I am looking for is a point in the right direction of information i can read. the rslogix online manual in the program has not helped me in the least setting up the array part of the sequencer.
If the online help isn't thorough enough for you, go to the Instruction Set Reference.
http://www.ab.com/manuals/cl/1756-rm003f-en-p.pdf
Chapter 9 is dedicated to the Sequencer instructions in the Logix family of controllers.
It sounds to me like you simply haven't created the Array tag yet; just because you type it in as an argument doesn't make the controller create it. Go to the Tag database for your program and make sure the Array exists as an array already !
Your post was a litle abrupt; it always helps to post a little of what you've already tried and the specifics of your error message... especially if you're a student.
thanks for replying. i did have an array tag made but i made it tha wrong way. i had: seq_array[0] as the tag name and it didn't like the [0]. my teacher didn't know how to fix it either until he sat down with me and we worked it out together creating another array tag as a test. :)
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
76
Hello, Does anyone have one of these cables and willing to open the case so I can see the cable connections inside? 2707-NC5 I have sourced the...
67
Currently trying to find: micrologix ethernet interface 1761-NET-ENI AIC to micrologix 761-CBL-AM00 Ser C cable These are used for micrologix...
124
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
170
455
